Scissoring Markers with MP Plotters
Kathy ValadeKathy Valade Gerber Staff 💛
edited January 25 in Plotter
When markers are wider than the width of the plotter paper, scissoring them is necessary. This way the marker sections can be attached after they are plotted on paper. When using the MP Plotter, the Plotter Settings Scissor option should be set to MAX to plot each section correctly and so the little triangles are printed with each section. This option maximizes the full width of the paper based on the Width value that is defined. Be sure that the same paper Width matches up with the paper width defined in Server Manager and that User Manager Default Print Settings is set to "Split file is wider than paper and margins".
You will need to edit the DEFAULT media and save it under a new media name.
Choose this media in Marker Plot Processing or in the Marker Plot Options so it defaults to the new media. Then, update the AccuMark Plot Queue with the new media name.
