Problem with copy grade rule, and move points
Dear, All,
i have some issue with copy grade rule from the time i installed Accumark  v11.
When i use the function the triangle point  appears  just at the same grading point, and sometime the grade rule cannot be copied. At the same time if i try to move the point using Modify/Smooth the point doesn't  move correctly . It moves somehow, but not with the right amount.
I already have sent the issue to Gerber, but no answer till the moments.
