Plotting Cut Pieces w/ Notches
Hi All,
Is there a way to plot so that the pattern pieces are cut out around the cut edge but the notches are drawn in by the pen?
Thanks!
  • The depends on what you are using to plot/cut.  If you are using an sp120 or sp150, or sp200 plotters no.  AccuMark will not see the notches as a separate entity and will cut them both or plot them both.  If you have a single ply cutter such as the Gerber DCS series you can accomplish this using the cutter software.
  • Hi @LisaEngel
    I am using a Graphtec Cutting Plotter CE6000-120AP so I don't think I can achieve that.
    Thanks for the help!
