Tip - Turning off Edge fills for OMEGA CS
When importing other file types into Composer, they often have Gerber Edge spot or process colors in the job.  These fills result in GSPplot paneling a job at 11.8" rather than the full size of the plotter cut area.
To remove the fills or strokes:  press F2 (to select all). Then press Control +1 (to turn off fills).  Press Control + 2 (to turn off strokes).
This will change a print or print/cut job into a cut only job to send to the plotter and remove the 11.8" panel line
