Default Parameter Tables
Jaye BrownJaye Brown Posts: 115 Gerber Staff 💛
Have you ever wondered what's the purpose of the different default parameter tables found when a new storage area is created?  Well...now, we have you covered with our quick list Default Parameter Table Guide.  I hope it's helpful.  Please feel free to comment and share your thoughts!
Jaye
    Great!  Love it!
  • Sue CarrierSue Carrier Posts: 112 Gerber Staff 💛
    You can select to use System Defaults or a storage area for default parameter tables when creating new storage areas or running check files on existing storage areas.
    Set New Defaults — the system will automatically copy the all of the parameter tables from the specified storage area when you create new storage areas.  In addition, it will copy all the basic data including Alteration, Annotation, Block Buffer, Lay limits, Rule Tables, and Size Codes from this Storage Area to the newly made one.
    TIP: If you plan to use "Set New Defaults," create a master Storage Area with all basic data items and parameter tables each newly created Storage Area will need.
    A warning will display if the New Defaults area is a version 9 Storage Area while creating a version 8 Storage Area.
  • Kathy ValadeKathy Valade Posts: 623 Gerber Staff 💛
    Great tips on keeping this concept together!
  • Abhi_IrinaAbhi_Irina Posts: 51
    What would be "Master Storage Area"?
    Does P-Notch parameters in the file supposed to match the Notch Conversion in Preferences?
    edited May 4
    Your P-Notch table details are referenced in PDS Preference on the "Paths" tab. The Style tab is specific to MicroMark conversions. If you were converting MicroMark data, it would be referencing the P-Notch table that is defined in your Paths tab.
