Split pieces result in Easy Marking not accurate
Hello All! I have done Split pieces in Easy Marking using From Left and From Bottom but the result is not accurate. The original rectangle measurement is 20x10cm, the result is 1.90cm more than the original. Can someone advise me for the solution? Thanks.
