How to restore the command line in CutWorks Designer
At times a customer or Engineer will ask how to restore the Command Line in CutWorks Designer, this line shows commands and steps to be done in Designer and can accidental be closed. The easiest way to restore the command line is to press the F2 key which brings up a text dialog box then type Commandline on the command line of the Text Window.then press enter. The command line will be restored.
David
