Lookups
rahulrahul Channel Partner Member
Hi Team
Please let me know lookups functionality in General Validation table
  • Erica ClendeningErica Clendening Gerber Staff 💛
    Hi @rahul!
    Lookups are part of YuniquePLM configurability which is used to create "lookups" or dropdown lists that feed customer-created fields. You can double-click on a header to add or edit a "lookup" field. If the user has full access to lookups in the Control Panel, then the user should be able to add records to the lookup tables. I have included a video below showing an example of the functionality.
    Hope this helps!
