Accumark Explorer
We are running v9. We changed the key from the front to the back of the computer today.
But we lost the Quick Fliter Bar and the Tool Bar  in Explorer.
We tried View (toolbar) with no luck
regards
    Hello Darren,
    Open a windows explorer window, go to
    c:\documents and settings\Username who lost the toobar\application data\Gerber Technology\roaming\AccuMark Explorer\AMXPLORE.ini
    Delete the AMXPLORE.ini file  If your not finding the file tell me what operating system do you have and I can send different information.
  • darrenbeamandarrenbeaman Posts: 71
    many thanks it worked
    edited November 2018
    You're Welcome!
  • Kit_KKit_K Posts: 13
    We also lost our quick filter bar and tool bar in AccuMark Explorer version 8.5.1.137 . I went into View>Toolbar and the the toolbar is currently selected.  I tried deselected the toolbar and checked it again to see what would happen.  Nothing happened during that process.
    I tried following the advice you gave to Darren but got lost in the process.   I went into Devices and Drives >> Selected Windows (C:) and I can't find a "document and setting" folder.  I tried roaming through each folder but had no luck.
    Our operating system is Windows 8.1.
    We look forward to resolving this issue.  Let me know if there is further information you require.
  • fortizfortiz Posts: 28
    Hello Lisa...
    I lost the tool bar that indicates marker info in EASY MARKING... I´ve tried to find the amxplore.ini file where U say but I cannot find Accumark Explorer folder...Do U know how to solve this for AM13 vs W10?
    Thanks and Best Regards
  • VasylVasyl Posts: 1,078 ✭✭✭
    The MarkerInfo bar not related with AExplrer toolbar. Cos solutions not working.
    I'm not knowing v13. But Info bar can be minimised, set to autohide, etc.
    You've to check something like View-layuout-MarkerInfoBar
  • MuhammadOwaisMuhammadOwais Posts: 371 ✭✭✭
    @fortiz
    Sometime the info bar get behind the taskbar. Try following steps,
    1. Turn Auto-Hide task bar ON
    2. When task bar get hidden, You will see the Info bar at the very bottom of the screen
    3. Drag the infobar out and lock in Easy Marking window
    4. Disable autohide taskbar if You want to...
    Hope this will help...
    Regards,
    Owais...
