Creating a Stroke but having the cut be the edge of that stroke
Greetings. This is a pretty simple question. Sorry if it has been asked before....... IF you draw a circle in Composer and  you add a .500 or 1.00 stroke to it…..How do I adjust the file to where the cut will be on the outer side or the inner side of the stroked circle instead of the actual diameter of that circle?  In otherwords, have the cut be made where the added stroke is.
Thanks for your help, community.
Tom Franklin
  • Michael CookseyMichael Cooksey Gerber Staff 💛
    Hi @Tom Franklin sorry for the delay in replying; I'm going to move this thread into the Signs and Graphics category, and find someone to assist. Stay tuned!
  • Adam FosterAdam Foster Gerber Staff 💛
    Hi Tom,
     The plotter can only cut on objects not strokes. Depending on the version of Omega you have you can select the stroked object then goto Tools menu and select "expand strokes" option. This will create objects where the thickness of the stroke is displayed. This then gives you a line that the plotter can cut.
