Delete
vincityhn1vincityhn1 Posts: 1
I want to delete a webPDM service. But
I tried to reinstall webPDM server and it failed because of an existing instance of service which was pointing the wrong folder.
Thanks.
  • Joseph LauJoseph Lau Posts: 15 Gerber Staff 💛
    Thanks for your question.  Here is the answer which will help:
    If you tried to reinstall webPDM server and it failed because of an existing instance of service which was pointing the wrong folder. Here are the steps to delete the existing service:
    1. Start the registry editor (regedit.exe)
    2. Move to the HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services key
    3. Select the key of the service you want to delete
    4. From the Edit menu select Delete
    5. You will be prompted "Are you sure you want to delete this Key" click Yes
    6. Exit the registry editor
    You can also find this information from my previous post here.
