Can not set Priority between Accunest V11 and older version
bickinbickin Posts: 87 ✭✭
Older version Accunest has got High, Low, and Normal. But New version is using number in priority.
If accunest server is old version, V11 Job Submission can not set priority. If accunest server new version, old version Jobsubmissin can not too.
Does have any way to work between old and new version accunest?
Not: If the jobsubmisson is different with installed accumark version, selection can not using.
    You should not mix versions of Queue Submit, if your Queue Submit is an older version then your AccuMark ALL of your Queue submit versions AND your AccuNest version should all be the same.
