Edit Delta
DardarmarDardarmar Posts: 16
  In pattern design,I need to adjust a point based on changes I made to each graded size. I know that there is a way to click the size in the delta and then select the piece I edited and place it in that spot on the created size. But when I try to do this now, if I select a size, it also selects other sizes with it so I can't just move one size within the grade. I know I've done this in the past on other systems, but I can't figure it out now.
