Customer opening under dxf file for the cutter
When opening the dxf file thru cutworks, you need to create master parts list in order to use retoolpath or nesting tool. If you just open the dxf file and send it to cutter it will cut your piece randomly and not sequence. This will waste your production time and time consuming. Here is sample pictures. I also showed the shortcut key. This also could be useful with multiply cutter too.
