How to adjust the appearance of the pattern pieces and piece icons?
tidivi23tidivi23 Posts: 150 ✭✭
The outline of the pattern pieces are appearing much lighter on the screen than usual and the piece icons in the work are at the top of the screen are also showing up very small. How can these details be adjusted? I've attached an image for easy reference.
  • EricFromBCEricFromBC Posts: 83 ✭✭
    Edit\Customize\Preferences\Color
    You can customize the color of different parts of your work area, icons and outline of pieces. I actually really like having the pieces in 25% opacity fill (Filled Pieces is under Display tab).
    I don't know how to make the icons in the icon menu bigger.
  • MuhammadOwaisMuhammadOwais Posts: 466 ✭✭✭
    @tidivi23 Looks like You are using very high resolution on the screen. try setting it on 1920x1080 from window personalization menu...
