V15.1 PDS Internal Cutout - Close - Seam Allowance
in AccuMark
Hi all,
Is this something PDS cannot do, or me not doing it correctly?
A piece with an internal cutout...
When I close it, all the notches turned into the opening.
If I add the seam allowance, they go to the wrong side of the cutout.
Thanks in advance.
Thanks in advance.
Also tried selecting only the closed H line and add seam allowance to that. The seam is added to the wrong side regardless of positive or negative value.
I also tried splitting the line and rejoined to trick the notches to inside the cutout. Thought they would flip the other way when I close the H. They did not flip direction as in my original post. Adding seam to that also have the seam result.
Draw a new simple closed H cutout. Adding seam to that work correctly.
With the seam on, adding more points to the line and moving them to the shape I want.
So far so good.
Still good.
Too early to celebrate...as soon as the line is bent, the seam allowance jumped to the wrong side.
I guess the shape is too challenging for PDS.
Next label H,
Next seam allowance
Thank you, moving the joint over solved the seam issue.
However, to start at that corner may have higher chance of heel cut.
