Cutting Question?
We are having an issue with piece bundles having a lot of frayed edges. I think I know what's causing the issue but would like to know if there is a solution.
Here is a screenshot of our marker
Here is a screenshot of a cut bundle
I believe this is happening when we have to perimeter lines butted together with no buffering.
We are using a XLC7000 Cutter but we do not have cutworks.
Is this normal or is there a settings that could be adjusted?
Thanks,
Veronica
Thanks,
Veronica
In case there is a very small distance between lines, you may activate the "common-line"-feature in CutWorksMPC or C200MT.
You need to enable "Auto Preprocess" and activate "Common Line". The remaining settings need to be adjusted to your favor.
Thanks Again!
