I cant import some of my zip files, How can I solve this problem?
MorreMorre Posts: 2
Hi, When I try to import some of my ziped files I get a pop up window that says: Error unzipping file.
Has anyone had the same problem or know what could be wrong with the files that Im trying to import?
  • ScottMCCScottMCC Posts: 45
    I was under the impression it could only import zip files generated by the export to zip feature of accumark explorer.  If your trying to import a generic zip file with say dxf's in it etc. it won't work.
  • MuhammadOwaisMuhammadOwais Posts: 456 ✭✭✭
    If You are trying to import *.dxf file directly into the storage area it won't work as You have to use DCU for that.
    Also sometimes the other side sends data (userroot or storage area) directly zipped  from Windows explorer. Try to open the zip file directly and if You see any folder in it, just unzip it and copy it in any of the userroot folder...
  • MorreMorre Posts: 2
    Its the files generated by the export to zip feature of accumark that cant be imported. I also have problem exporting. I tried to export with Data convertion utility but that doesnt work either.
    @Morre Are You importing in the same storage area versions...!!!
  • andego1986andego1986 Posts: 63
    What type of zip files are they? Are they accumark zip files or zip files from other programs. Be more specific
