Remove Stack Attribute
Hey y'all! Another challenge using Edit Delta: When attempting to select a specific point for modification, I received the below warning
Note that I tried to circumvent issue by selecting previous and subsequent points, using next/previous to land on this point, but it just skips over. How do I remove stack attribute from piece for modification, and will this potentially cause other problems?
1. Edit - point info - attribute. And remove Z.
Or
2. Grade - view - reStacking. And point with stacking. This command add stacking attribute or! Remove, if Z was added early.
There in corner present 2 points. Cos if there no set "apply both" option (or some like this) on prev window (Edit - Point info) then you select wrong point.
In your case. I mean you select point of bottom line but Z applied to point of side vertical line
Restack can be from any point - Grade, View, Restack [changes the z stack location] - does not trigger editing etc.
