Half segment of a mirrored piece cuts slower than actual feed rate in Paragon
In Paragon cutter while cutting a mirrored piece with asymmetric attributes, half segment cuts with normal speed but when it starts cutting the other half of a piece the cutting speed slows down almost half of the main feed rate. We have checked in other cutters like XLc 7000 & other brands where the same cut file does not show this problem. We have checked all settings of axis software and disabled all slow down commands but could not find any solution. I am suspecting it is mainly cut file related issue, may be in the patterns generation in Accumark. Cordially asking for a solution/suggestion regarding this.
Thanks In Advance
Hanif
