Additional Cut Mark of Autocutter Paragon
When I cut Layer There was abnormal thing happen. That is the Additional Cut Mark at lift and plunged Point. like image shown in below
More Over When I overview Cutworks Software regarding Cut file Belong to this layer, There was different Shape Point in there . image shown in below
This Line Should Be Straight Line But at There like this. When Cutting Process other part nearby this part was damage because of this cut mark, What Can be Happen Please?
I checked the Accumark Pattern Also for at that point that shown like this way in the image attached
What Can be Reason For this Issue. ?
Appreciate Your Idea to solve this
Is the second image extremely zoomed? The angle at the top is probably what caused the lift and plunge.
PDS could not zoom in that close. Try move single point and see it there is actually two points very close to one another. Just have to delete one of the points.
This usually happened when the piece is create with tracing.
Yes Second image is extremally zoom. this images is zoom out one of the 2nd image.. furthermore 2nd image shown s data point distance approx 0.3mm
I'm Agree with you regarding the Data points arrangement, is there no any option that can set setting to prevent this kind of happen from ACCUMARK or PARAGON AXIS SOFTWARE setting ???/
