Annotation lines
I have found some discussions, but please can you clarify -
I want to move the annotation to stay with the grain line in a place in the piece.
Do I Create an extra line in the pattern in PDS, then edit line info and put A in the Label box?
Will this make the pattern annotation stay where the line is?
Thanks for your questions. Please visit the Lectra.com website to create a support ticket with the customer support office connected to your region.
You can use the link: https://www.lectra.com/en/about-us/lectra-and-gerber-technology#additional-resources-for-gerber-customers
Once a support ticket has been created, then a support team member will be able to connect with you on a 1:1 basis to troubleshoot your issue.
I hope this is clear and helps.
CAD Support
In P-Piece-Plot, the option Piece Annotation can choose between Grain and Center.
In P-Marker-Plot, Annotation section, the option Piece can choose between None, All Center, and All Grain.
Internal line with either Label A or Label B is an extra options. Once you have a Label A/B on a piece, it overrides what was chosen in the parameter.
You can also use multiples A/B lines... sometimes I cheat the cutter with internal cut lines and need the piece annotation appears multiple times on a piece, so the bundler don't throw the piece away.
