Cutting Outside Notches
I am having an issue with our DCS1500 cutter. When using a notching tool to cut outside notches, they are cut off when the perimeter is cut. I cannot cut them with the tangential blade due to material properties (thickness and construction). I also do not see any method to invert or flip the notches within CutWorks.
Base Pattern:
After Notch Conversion:
Any advice is appreciated.
Base Pattern:
cutworks is a different software than accumark, that being said the way cutworks reads the notches is by data which is what that notch point is that you have snipped. you can do all kinds of different notches inside of accumark but cutworks reads them all as just data and will assign them to whatever you have that layer mapped to on your machine. in this case go to edit and either auto merge or auto convert i cant remember which one and fill out the middle column for v notches, though i have never done that with inverse v notches so im not sure that will actually work and sometimes its buggy and doesnt do them all. another way to get around this is to dxf the piece out with the notches on it, the dxf process will convert them and then just import it back.
