Generate Cut data problem
lorenalopezlorenalopez Posts: 2
I'm having a problem generation cut data but is just for an specific pattern style I have... when I select generate cut data over my marker the process result is failure... does anyone know why it this?
  • VasylVasyl Posts: 1,463 ✭✭✭✭
    Answer ✓
    You've find problem piece.
    Return back all pieces from marker.
    Next. Place some piece in marker. And generate cut data. If you'll get failure tgen you found the problem piece.
    If there will no failure then add next piece to marker and generate.....
