C200MT CONFIGURATION TO CUT CONTOUR BANDS FIRST
freyesl102freyesl102 Posts: 1
edited February 13 in AccuMark
Good morning,
We use C200MT software to cut all piece goods. How may we configure our cutting settings to  always cut the contour bands first in our markers? Here is an example of a marker set:
  • VasylVasyl Posts: 1,465 ✭✭✭✭
    edited February 14
    There You have set piece's priority by pieces category in p-cutter setting. And use last one while generating cut file.
    PS: i suppose there can be set priority cutting internals by labels.
  • Sandro PalumboSandro Palumbo Posts: 70 Gerber Staff 💛
    Hi, you can do that how Vasyl suggest, otherwise you have 2 method :
    1 - on cutter, after marker opened, press F2 and insert the piece number you wanna cut. After cutted, close and reopen the marker, skip the pieces already cutted and continue to cut normaly.
    2 - via Accumark. On Marker Making there is a menu called Cut Sequence, where you can decide the sequence of cut. Attahced you can found image that show this proscess. On Marker making pic, on pieces you can see the sequence number (1,2,3,ect). In first case the prder start from left buttom to right. After change the sequence, the order of cutting is changend (first cut the 2 col).
