MARKER PLOT_ ANNOTATION
How do i plot marker with pattern pieces numbered , for example 1(10) , 2(10) etc?
What do i select in "annotation"
Thank you .
Thank you .
But you may define for yourself the first 2 symbols in description/category is a number. For example: 02 2 cut.
And set annotation for piece:
PN1-50 - print all piece name
SZ1-10 - print size
PS. Usually i prefer instead "piece name" in marker print "model nane" and "piece category"
For why make blocks?
I do want to put different size markers onto one to safe blank spaces when plotting them. Thank you
Select Bundle - proper command in menu - and place pieces. For quick placing you may use AutoSlide tool.
next set bump vertical line - proper command in menu - add some space
next Select Bundle - proper command in menu - and place next size/bundle's pieces.
etc
If you have accunest tgen you may use section marker. Define section as bundles
