Paragon Cutter Not Cutting Slit Notches
brianbradburnbrianbradburn Posts: 2
edited November 2022 in Multi-Ply Cutter (MPC)
We have a Paragon cutter and we are trying to cut a marker with a mix of V-Notches and slit notches. We have cut this product before, but now it won't cut slit notches. We had the software updated since the last time we cut this product. Plus someone was fooling around with the cutter backup, trying o fix another problem, and wiped out all our settings.
  • DOINADOINA Posts: 4
    hello ! Try from paragon cutter . parameters from lead in or lead out ! And then to alternate lead in and lead out ! so the cutter can make a media between notches !
    or try to create from pds a notch table with slit and V notch ! on slit - put the depth 0.40 and on V notch -perimeter width 0.60 and depth -0.5 ! generate marker with this notch table !
  • ayoinfiayoinfi Posts: 15
    you have take recently auto created Back on on your C drive -----> Program file*86-----> Gerbertechnology ------> Axis Software---> Image Back up
    then Search the date the nearest for back take that copy and paste another location restore  ur cutter then it will be able to back to normal
  • ASMITHASMITH Posts: 20
    If paragon is using cutworks, v notch is one layer and slit notches are another and so on for any other different type of notch. if your machine layer settings were deleted then more than likely you just need to go into your machine settings and reset up the layers to the correct tools. i created a piece in accumark with every layer and or notch we did here so that when this happens you can remap everything at the same time.
