View Cut direction in PDS on internal cuts
Is there a quick way you can check which way the knife will cut on an internal slit cut in PDS?
I know that when you create an internal line that the knife will follow the direction in which it is created but is there any way you can check or verify the cut direction after the line has been created?
If this is possible, is it possible to change the cut direction of a slit cut without having to delete and create a new slit in the way you want it cut?
