How to export Accumark to DXF file where the seam shows in DXF as a dotted line
Using V14 Accumark
All my pieces exported into DXF have solid lines and not dotted lines
1)Is it possible to export Accumark pieces via DXF and open pieces up in DXF to see the seam line "dotted".
2)If it is possible, then what do you need to change in your settings to make this happen.
You can refer to online help for details:
• To plot the label as a line: type LT0 to make the line invisible, LT1 to plot the line as a solid line and LT2 to plot the line as a dashed line.
Can you help?
You could try generating the data as DXF plot data which would generate standard DXF and that may show the dotted line and what you would expect if say, importing into Illustrator since that program imports standard DXF format. Try generating patterns in PDS and with your Piece Plot Options set to DXF. Turn on the option to generate a single plot file as one DXF file. Be sure you have an Annotation table with LT2 in it and that is in your PDS Preferences.
Is there anything else that can be done or checked?
Please let me know
