SYSTEM CRASHING WHEN OPENING MODEL
in AccuMark
Hi there!
One of our newly acquired on-line licensed machine is crashing but only when we attempt to open model.
The message appears with System Configuration ERROR see pix attached.
We installed couple of weeks ago the only hotfix available in the user portal.
Previously it was not just crashing it was just disappearing from the screen, the explorer and everything with it.
After we installed the hotfix for V14.2.0 its not disappearing, but its impossible to open MODEL for editing.
It was a default installation preference, from online user access, stand-alone machine, so storage areas are on "C" drive.
And where do I "start with the Customer Solutions Center"?
your problem is user.config file is not saved correctly.
open run window and paste the below folder way.
%LocalAppData%\Gerber_Technology,_a_Lect\
you will see some folder and each folder has user.config file. one of config file was not saved correctly. But firstly you have to know about XML file format roles to fixed this problem. This is technical information. You can visit this site to learn XML Syntax (w3schools.com)
But the biggest role is that all notes have to closes tag. And you find this problem in user.config file and write manuel.
Also, since the hotfix there is another model editor issue with active sizes and that is being addressed soon.
Like I said asbove:
At this point I feel like reinstalling fresh, my question is what is the protocol for re-installation? and how do I preserve the working files this user has on her machine?
Was there hotfix for the issue?
2 months later I now have issue with EXPLORER crashing.
https://gerbertechnology.vanillacommunity.com/discussion/comment/7372/#Comment_7372
My logic tells me the HotFix should be posted on users profile, at least it was previously...
Right now on the Gerber Customer Profile is a box under Downloads for "AccuMark Family 15.0.0 Installer"
Does it mean I need to install it?
I would recommend that you email [email protected] or call your local support office if you need further assistance.
Received the response from support!
Sent in further questions.
