Cutter is shrinking pieces
when cutting the pieces they are about 1/8" smaller all around. No shrink on pattern. looks as if buffer was applied, no buffer applied to marker.
There could be multiple reasons for that. Check the following areas in AccuMark for shrinkage:
1. Check in the Model
2. Check in the Order
3. Check the Marker Plot parameter
4. Check the Cutter Parameter
5. if all of the above are correct, then It might be due to wrong calibration of the Plotter (if Manual cutting) or Scaling at Cutter (if Auto Cutting)...
Regards,
Owais...
If the plotter hasn't calibration feature then use Scaling in P-Marker/Piece-Plot
