Internals not being imported into AccuMark
After digitising a piece that contains internal lines, when I open it on AccuMark, the internal lines are not there. The internals do appear on Wdigit whilst digitising. It has been working fine previously, Is an option currently enabled/disabled?
  • Kathy ValadeKathy Valade Posts: 688 Gerber Staff 💛
    The internal lines should show on your pieces if the internal is defined as a supported internal label ID. Be sure you are digitizing it in correctly and as expected.
  • I believe I am digitising the same way as I have done previously and I can see the internal lines being added as I digitise. However, upon it being opened on AccuMark, these lines (Internal, I) or circles (Internal, H, Circle CTR RAD) do not show. I can still see internal lines on digitised pieces made previously when opened on AccuMark, however any new patterns that I digitise will only have the external lines.
