PDS Grading Smooth function
Has anyone used the Grade\smooth function?  The help files say"Use to automatically create smoother grading along a curve.  The result is similar to removing the grade rule(s) along a curve to allow the curve to “relax” and then using the function Add Grade Point to add grade points back in."  I tried it and I see no difference in my line.  It does the same thing as grade\modify\add grade point.  Is there a difference?
You are your own Destiny
