lectra alys plotter
DebcushmanDebcushman Posts: 2
Having a problem with dimensions when sending a marker plot to a plt file
and then plotting it on the Alys Lectra plotter the dimensions of the marker changes ?
How do we fix this ???
  • bickinbickin Posts: 102 ✭✭✭
    which software are you using to send Hpgl? I think your problem inch multiplier. lectra using 0,25 but you are using 0,254 in gerber
  • VasylVasyl Posts: 1,078 ✭✭✭
    Debcushman сказав:
    You can open plt in some hpglviewer as well CorelDraw and check dimensions.
    But... It's matter what resolution application will apply. For example.
    The Accumark counting 1016 dpi... And if you'll open lastone in Corel, but leave 1000dpi as default then Corel shows change d dimensions.
    1st. You have to check and march settings in cad and alys's plotting software
    2nd. Make plotter's calibration
