Apply alter Size seam Error
FawadFawad Posts: 22
Hello, i am alter my pc, and see this error, any one who help me why this error show & how i remove this error
  • VasylVasyl Posts: 1,078 ✭✭✭
    Hi.
    Swap seam to cut.
    Fix perimeter as cut.
    Try again. If problem is remaining then "copy piece no seam".
  • Kathy ValadeKathy Valade Posts: 672 Gerber Staff 💛
    You may also want to be sure you are using auto update seams to maintain proper sew lines.
  • FawadFawad Posts: 22
    ok i did it, but see error again, may be it is a Seem error that i use Uneven seams.
    its disolve when i remove uneven seams. but i want to do with seam its gerber Programing error, may be
    Not all features allowed for uneven seam.
    Cos you've to do next:
    1. "Fix peimeter". Select proper option under tips.
    If it's not resolve issue. Then
    2.  If piece's perimeter is sew line then   swap perimeter to cut line. Fix perimeter... Try one more command you need.
    If it's not helpful then "copy pieces no seam".
    The lastone have to be available for your command.
