Paragon Cutter
Hi, We are running a paragon cutter and have an issue of the cutter stopping after moving the machine bed, usually the cutter automatically starts again but we have to manually select start. Ive explained the steps below:
1. We load the file and select start
2. It cuts the beginning of the program up until it has to move the cutting bed.
3. Cutting bed moves up ready to cut the next section of the layout but it stops and we have to manually select start.
Any idea what might be causing this.
If this is unticked, the cutter continues after bite feed without any user intervention.
