Gerber pattern design mirror lines converted in Autocad
DGallinoDGallino Posts: 11
When we send a mirrored piece over to Autocad, the mirrored line in Autocad isn't the same length as the piece in Gerber. We are using Gerber V13. Its interesting though because it doesn't happen with every piece only on certain pieces. If anyone has a solution for this please let me know.
  • VasylVasyl Posts: 1,040 ✭✭✭
    edited October 4
    Hi. What is missmatch?
  • DGallinoDGallino Posts: 11
    @Vasyl It seems the Mirrored line is converting into AutoCAD incorrectly. I don't believe this is a conversion issue however based on the fact that the rest of the piece comes in the correct size. Example: say we had a square with a mirrored line and the mirror line goes top to bottom in Gerber. When we send it to AutoCAD the line would would still be in the center but it wouldn't reach both ends of the piece.
    @DGallino, if your piece has active perimeter a seem then try to swap seem/cut to make acive perimeter a cut line. And then convert one more to check.
