Matching Patterns and Stripes in accumark
neotexneotex Posts: 2
Is there any up-to-date information on how to do plaid and stripe matching in accumark?
Most of the information online is fragmented between old PDF files, small posts here on the forums or quick 1-minute videos on YouTube.
I've also checked inside Gerber University and did not see any lessons on the subject.
  • VasylVasyl Posts: 1,040 ✭✭✭
    I. Lines
    you may use next Labels:
    0 - Match Piece to fabric (stripe/plaid)
    1 - Match Left to Rigth piece
    2... - Match left to other left (sleeve yo front etc).
    There you may set poper type matching (relative, symmetric) in marker.
    II. Points.
    Assign to corespond poins some id (i prefer 4digit)
    And set proper rules in Matching table in Order.
    There you set , for example, the piece with category FRONT with point 1001 have to relative match to pieces SLEEVE with point id 1002 via stripe...
    Lastone metog is more hard to create schema. But can be aplied to diffrent model cos using piece's categories not names
  • neotexneotex Posts: 2
    Thank you for your response @Vasyl I will play around with this and advise if I have further questions.
