Accumark v13 PDS piece
bme13bme13 Posts: 6
I’m not very good at the pattern making part of plotting, but usually if a piece needs to be edited with a few lines or points that are moved here and there I can do it. But today my piece in pds shows the outside lines without the extra internal line but when I plot it on paper it has another inside line. I tried moving lines individually, move offset, and then tried modifying points in different ways but every time I saved my piece the bottom line is doubled. Is anyone able to help me figure out why?
  • VasylVasyl Posts: 942 ✭✭✭
    I suppose 2nd image is piece in PDS, 1st - ploted
    On ploted piece you see seew line as internal.
    To see lastones in PDas switch on Seam/Sew in rigth bottm corner.
    Otherwise your seams can be hided. Check some command in Advanced-Sew/seam - ...
    Sorry, i'm typing from smartfone.
