Import .plt file to an external plotter QHV3
TatyanaQTatyanaQ Posts: 6
Hello, Looking for assistance: I have an external  Plotter/cutter QHV3 , trying to send .plt files created in Gerber Accumark  to QHV3 plotter . The message comes up   ".plt file failed to import" . What could be the issue here?  Note: The plotter has ".plt test file " folder  .   they plot/cut  without any problems.
Best Answers
  • VasylVasyl Posts: 942 ✭✭✭
    Open plt file in notepad and post here some part of this
    As you see it's not plt format. Seems like generic.
    Cos you've open Model/Piece plot utility , go to View - plot options (preferences) and set not just plt extension, but set correct format - hpgl.
    If your file is a marker - not piece. Then open Marker plot utility and change format there.
    here is a sample of plt/hpgl file:
    <quote>
    IN;
    IP0,0,1016,1016;
    SC0,1000,0,1000;
    SP1;PU8391,7818;PD8392,7820,8393,7821,8394,7822,8397,7823,8456,7823,8472,7820,8484,7812,8492,7801,8495,7788,8491,7772,8477,7759,8489,7753,8498,7745,8503,7736,8505,7726,8504,7717,8500,7709,8495,7702,8487,7696,8477,7691,8467,7690,8397,7690,8394,7690,8393,7691,8392,7693,8391,7695,8392,7697,8393,7698,8394,7699,8397,7700,8409,7700,8409,7813,8397,7813,8394,7813,8393,7814,8392,7816,8391,7818;PU8418,7813;PD8418,7763,8452,7763,8462,7764,8471,7767,8477,7771,8482,7776,8485,7782,8486,7789,8483,7797,8477,7805,8468,7811,8456,7813,8418,7813;PU8452,7753;PD8418,7753,8418,7700,8466,7700,8474,7701,8482,7704,8487,7708,8492,7714,8494,7720,8495,7726,8494,7733,8490,7740,8484,7746,8476,7750,8466,7753,8452,7753;PU8543,7749;PD8543,7773,8547,7801,8558,7821,8571,7832,8587,7836,8596,7835,8603,7833,8610,7829,8616,7823,8619,7818,8623,7811,8627,7803,8629,7796,8631,7785,8632,7773,8632,7773,8632,7749,8628,7722,8616,7700,8604,7690,8588,7686,8579,7687,8572,7690,8565,7694,8559,7699,8556,7704,8552,7711,8548,7719,8546,7726,8544,7737,8543,7749;PU8553,7750;PD8554,7737,8557,7725,8561,7715,8565,7706,8568,7703,8573,7699,8580,7697,8588,7696,8602,7700,8613,7712,8620,7730,8622,7750,8622,7771,8621,7785,8618,7797,8614,7808,8610,7816,8606,7819,8602,7823,8595,7825,8587,7826,8573,7822,8562,7810,8555,7792,8553,7771,8553,7750;PU8678,7706;PD8678,7708,8678,7710,8679,7711,8680,7711,8682,7711,8684,7709,8703,7699,8723,7696,8738,7698,8751,7706,8760,7717,8762,7729,8761,7737,8757,7746,8750,7753,8742,7758,8731,7762,8721,7763,8718,7763,8716,7764,8715,7766,8714,7768,8715,7770,8716,7771,8718,7772,8720,7773,8728,7773,8740,7775,8750,7781,8756,7789,8758,7799,8756,7809,8749,7818,8739,7824,8726,7826,8716,7826,8707,7823,8699,7819,8692,7814,8691,7813,8689,7812,8688,7811,8687,7811,8685,7811,8683,7812,8682,7814,8682,7815,8684,7820,8692,7827,8708,7834,8725,7836,8742,7833,8756,7825,8765,7813,8768,7799,8767,7789,8762,7781,8755,7773,8746,7766,8746,7766,8757,7760,8765,7751,8770,7740,8772,7729,8768,7713,8758,7699,8742,7689,8723,7686,8711,7687,8698,7692,8687,7697,8679,7702,8678,7704,8678,7706;PU8814,7748;PD8814,7761,8912,7761,8912,7748,8814,7748;PU8937,7818;PD8937,7819,8938,7820,8939,7821,8940,7822,8941,7822,8943,7823,8980,7823,8982,7822,8983,7822,8984,7821,8985,7820,8985,7819,8985,7818,8985,7816,8985,7815,8984,7814,8983,7814,8982,7813,8980,7813,8961,7813,9003,7700,9003,7700,9045,7813,9026,7813,9024,7813,9022,7814,9021,7814,9021,7815,9020,7816,9020,7818,9020,7819,9021,7820,9021,7821,9022,7822,9024,7822,9026,7823,9062,7823,9064,7822,9066,7822,9067,7821,9067,7820,9068,7819,9068,7818,9068,7816,9067,7815,9066,7814,9066,7814,9064,7813,9062,7813,9055,7813,9009,7690,8996,7690,8950,7813,8943,7813,8941,7813,8940,7814,8939,7814,8938,7815,8937,7816,8937,7818;PU9083,7755;PD9088,7783,9101,7805,9120,7820,9141,7824,9156,7822,9170,7815,9182,7805,9191,7790,9197,7774,9199,7755,9199,7755,9197,7737,9191,7720,9182,7706,9170,7695,9156,7688,9141,7686,9120,7691,9101,7706,9088,7728,9083,7755;PU9093,7755;PD9097,7732,9108,7712,9123,7700,9141,7696,9160,7700,9176,7714,9186,7733,9189,7755,9189,7755,9186,7777,9176,7797,9160,7810,9141,7815,9123,7811,9107,7798,9096,7778,9093,7755;PU9224,7695;PD9224,7697,9225,7698,9227,7699,9229,7700,9252,7700,9252,7813,9229,7813,9227,7813,9225,7814,9224,7816,9224,7818,9224,7820,9225,7821,9227,7822,9229,7823,9285,7823,9288,7822,9290,7821,9291,7820,9291,7818,9291,7816,9290,7814,9288,7813,9285,7813,9262,7813,9262,7700,9326,7700,9326,7738,9326,7741,9327,7742,9328,7743,9330,7744,9332,7744,9334,7743,9335,7741,9335,7738,9335,7690,9229,7690,9227,7690,9225,7691,9224,7693,9224,7695;PU9349,7695;PD9349,7697,9350,7698,9352,7699,9354,7700,9362,7700,9404,7813,9376,7813,9373,7813,9371,7814,9370,7816,9370,7818,9370,7820,9371,7821,9373,7822,9376,7823,9428,7823,9474,7700,9479,7700,9482,7699,9484,7698,9485,7697,9485,7695,9485,7693,9484,7691,9482,7690,9479,7690,9445,7690,9442,7690,9440,7691,9439,7693,9439,7695,9439,7697,9440,7698,9442,7699,9445,7700,9463,7700,9451,7734,9385,7734,9372,7700,9389,7700,9392,7699,9393,7698,9394,7697,9395,7695,9394,7693,9393,7691,9392,7690,9389,7690,9354,7690,9352,7690,9350,7691,9349,7693,9349,7695;PU9388,7744;PD9447,7744,9422,7813,9414,7813,9388,7744;PU9493,7818;PD9493,7820,9494,7821,9496,7822,9499,7823,9523,7823,9591,7703,9591,7813,9574,7813,9571,7813,9569,7814,9568,7816,9568,7818,9568,7820,9569,7821,9571,7822,9574,7823,9606,7823,9609,7822,9611,7821,9612,7820,9612,7818,9612,7816,9611,7814,9609,7813,9606,7813,9600,7813,9600,7690,9588,7690,9520,7809,9520,7700,9537,7700,9540,7699,9541,7698,9542,7697,9543,7695,9542,7693,9541,7691,9540,7690,9537,7690,9504,7690,9502,7690,9500,7691,9499,7693,9499,7695,9499,7697,9500,7698,9502,7699,9504,7700,9510,7700,9510,7813,9499,7813,9496,7813,9494,7814,9493,7816,9493,7818;PU8643,7412;PD8642,7403,8639,7395,8635,7388,8630,7383,8621,7378,8612,7374,8605,7372,8596,7372,8566,7372,8566,7328,8599,7328,8602,7327,8603,7326,8604,7325,8605,7323,8604,7321,8603,7319,8602,7318,8599,7318,8545,7318,8542,7318,8541,7319,8540,7321,8539,7323,8540,7325,8541,7326,8542,7327,8545,7328,8557,7328,8557,7441,8545,7441,8542,7441,8541,7442,8540,7444,8539,7446,8540,7448,8541,7449,8542,7450,8545,7451,8599,7451,8617,7448,8631,7439,8640,7426,8643,7412;PU8634,7412;PD8631,7423,8624,7432,8613,7439,8600,7441,8566,7441,8566,7381,8596,7381,8607,7383,8616,7386,8624,7391,8629,7397,8633,7405,8634,7412;PU8682,7446;PD8683,7447,8684,7449,8685,7450,8687,7450,8732,7464,8732,7328,8764,7328,8767,7327,8769,7326,8770,7325,8770,7323,8770,7321,8769,7319,8767,7318,8764,7318,8689,7318,8687,7318,8685,7319,8684,7321,8684,7323,8684,7325,8685,7326,8687,7327,8689,7328,8722,7328,8722,7451,8690,7442,8688,7441,8687,7441,8685,7441,8684,7442,8683,7444,8682,7446;PU9001,7375;PD9001,7388,9004,7402,9008,7418,9015,7436,9022,7451,9027,7459,9029,7460,9030,7460,9032,7460,9034,7459,9035,7457,9035,7456,9035,7454,9034,7453,9023,7431,9016,7412,9012,7393,9010,7375,9012,7356,9016,7338,9023,7318,9034,7296,9035,7295,9035,7294,9035,7292,9033,7291,9032,7290,9030,7289,9029,7289,9027,7290,9023,7298,9015,7313,9008,7330,9004,7346,9001,7360,9001,7375,9001,7375;PU9098,7446;PD9098,7447,9099,7449,9100,7450,9103,7450,9147,7464,9147,7328,9179,7328,9182,7327,9184,7326,9185,7325,9185,7323,9185,7321,9184,7319,9182,7318,9179,7318,9104,7318,9102,7318,9100,7319,9099,7321,9099,7323,9099,7325,9100,7326,9102,7327,9104,7328,9137,7328,9137,7451,9105,7442,9103,7441,9102,7441,9100,7441,9099,7442,9098,7444,9098,7446;PU9229,7318;PD9229,7331,9258,7358,9285,7385,9295,7396,9302,7404,9306,7409,9308,7414,9310,7419,9310,7423,9308,7435,9300,7445,9290,7452,9277,7454,9265,7453,9255,7447,9247,7440,9243,7430,9242,7428,9241,7427,9240,7426,9238,7426,9236,7426,9235,7427,9234,7428,9233,7430,9235,7436,9239,7444,9246,7453,9255,7459,9266,7463,9277,7464,9293,7461,9307,7452,9317,7439,9320,7424,9319,7417,9318,7412,9315,7407,9311,7400,9303,7392,9292,7381,9263,7351,9239,7329,9239,7328,9310,7328,9310,7331,9311,7334,9312,7336,9313,7337,9315,7337,9317,7337,9318,7336,9319,7334,9320,7331,9320,7318,9229,7318;PU9385,7294;PD9385,7295,9386,7296,9397,7318,9405,7338,9409,7356,9410,7375,9409,7393,9405,7412,9397,7431,9386,7453,9385,7454,9385,7456,9386,7457,9387,7459,9389,7460,9391,7460,9392,7460,9393,7459,9398,7451,9405,7437,9412,7419,9417,7404,9419,7389,9420,7375,9420,7375,9419,7361,9417,7347,9412,7331,9405,7313,9398,7298,9393,7291,9392,7290,9390,7289,9388,7290,9387,7291,9385,7292,9385,7294;PU8514,6951;PD8514,6949,8513,6947,8511,6946,8508,6946,8496,6946,8481,6973,8470,6989,8460,6998,8449,7006,8418,7006,8418,6956,8436,6956,8438,6955,8440,6954,8441,6953,8441,6951,8441,6949,8440,6947,8438,6946,8436,6946,8397,6946,8394,6946,8393,6947,8392,6949,8391,6951,8392,6953,8393,6954,8394,6955,8397,6956,8409,6956,8409,7069,8397,7069,8394,7069,8393,7070,8392,7072,8391,
    </quote>
  • TatyanaQTatyanaQ Posts: 6
    Hi Vasyl, I have opened the .plt file in notepad and posted the result below. It seems that the file is in some format that the notepad editor can not understand?
    ¾îj GENPTV1 ‡ ìy  Ô Wé    ×   ,  ô  ‰      ‰      ‰                    ÿÿÿÿÿÿÿÿ…   5
      ÿÿÿÿSAM_TSHIRT_SLV_TESTÿ    ‡ ìy  Ô Wé     G v- (@   pa (@    I rÇ ÷   rÇ ßР   I rÇ ÷   rÇ _      J I lû ÷   –¯ ÷   Ã ÷   rÇ ÷   "o ÷   Qß ÷   z“ ÷    " I rÇ ßР  v- ël   z“ ÷    @ I rÇ ßР  £B è€ £B è€ J? ¿{ £B è€ lû ÷    I v- ël   b( u    I £B 耠  %Q “™    " B c ùР   ¸ø ùР   ¸ø "    BSS z“ ÷   C§ Ü   "± ³   µº 2   Î ‚"   ›à @/  àê «7   ¸ô š@   O÷ C O÷ C £û ½> O÷ C ) 3Q
    íf   b( }    ; ‘   ‘N 2¤   èW ,¬   •a ¾³   ‰k   Íu ¨Á   Š FÇ   ‡‰ rÌ   ž Õ   B¨ Ù   £² ïÛ   rÇ óß   i× QÝ   ;ç Ú   :ø –Ô   È ãÍ   ´ ,Å   , h»   Æ> >¯   %Q —¢   Æh Ž   € y   ¸ êh   &˜ ê_ &˜ ê_ ¨“ ¶[ &˜ ê_ „§ }O   ÷« #K   †Å š2   ^Ñ –(   ‡Ý ô   lû ÷   wì ¸æ   Yß ÞÆ   Ó ¶¦   tÈ ˆ‡   Ö¾ h   2· GL   _° M0   ÷« s   6¥ Ûï
    Ÿ +Æ   .— £‹   ‘
    Y
    Œ X&   l‰ ­û    w‡ ùР   ú† 1Æ    ú† _     ¸ø _     ë _     ë 1Æ    L yú    ¶.   «ý .[   hø Ž‡   hï #Ç   ðè -ï   ùá #   ÜÝ e,   =× ÝF   ÙÏ #a   KÅ  ƒ   ß¹ ×¥   ¡­ Ç   Ç è   z“ ÷      Œ t ‡ é    Ž  Ž N’ Ú  Ž ¤ Œ   d­ (   d¶ b   .É W*   Û ­6   ÿä Í>   î jG   Ðð §I Ðð §I $õ JE Ðð §I Aþ UW   ! m   x! ;ƒ   ›4 ‘—   vH &«   R a³   \ 1»   [f ›Â   óp ŒÉ   { ]Ï   ^… ¸Ô   ë ¦Ù   ªš %Þ   i¥ àá   b° ää   jÇ Wé   žØ €æ   ªé üâ   Pû NÝ   ƒ YÖ   ð cÍ   Î0 Yà  öC ⶠ  ÍV è©   Ên •   f† ²   d– Io   ãž 7f ãž 7f eš b ãž 7f ® òU   d² ÃQ   §Ë ‚9   D× °/   0ã >&   6ÿ ¢ 6ÿ ¢ Àü ÿ 6ÿ ¢ Ô     \ \ þ  \ üô *ã   ôç ‡Ã   µÛ –£   ;Ñ ­„   ´Ç we   "À ùI   a¹ D.   µ Þ   S® gî   ,¨ ØÄ   W „Š   Lš X   =• —%   ¡’ û    ¯ „Р   4 ûÅ    4 _    4 _    Š _    4 _    4 ìy    ú† ìy  ú† ìy  ú† €  ú† ìy  ¸ø ìy    ë ìy  ë ìy  ë €  ë ìy  ±þ ìy    ±þ _    ±þ _    × _    ±þ _    ±þ îÅ    ü ÷ù    Òø ô-   ~ô ;Z    i†   Jæ ¹Å   Öß §í   åØ    ÝÔ T*   NÎ ‰D   þÆ ‹^   ¼ ΀   )± Ì¢   ù¤ Üà  0˜ ³ä   ˜Š Q ˜Š Q } ˜Š Q ‡ é   ÿ   M + Biû Ùý  l` ½ ê- Q  SAM_TSHIRT_SLV_TEST
    SLV
    CUT 2
    (48) VQ163ÿ  ÿÿ
    Thank you, Vasyl, for your help! I'll try and do  that. Will leave a comment here soon.
    Thank you, Vasyl, for you help. your explanation is simple and to the point. It worked. The file was successfully imported. Will be testing the plotter soon 👍🙂
    this is how mine looks like. Thank you again.
