cutting order
mdzmdz Posts: 1
i would like to know if its possible give a cutting order,  i want to cutting first notch/slits before pattern line... is it possible ?
  • SometimesIneedHelpSometimesIneedHelp Posts: 53
    you can specify what line to start with and then the order, you do this in PDS in he advanced tab all the way to the right is the cut sequence function
    You are your own Destiny
  • VasylVasyl Posts: 899 ✭✭✭
    @mdz
    1. I know this feature present in lectra's cutters.
    2. AccuMark is generating nothes as part of perimeter.
    but. thake in mind:
    1. in your order knife will punch every notch and fabric may deforms.
    2. a cutter will loos time to idle move from notch to notch.
