Knife setting of cut file does not use default settings of Graphtec CE6000 plotter
blairnewelblairnewel Posts: 1
I have set the conditions (Cond 8) of Cut on the Graphtec CE6000 for the speed and force which cuts nicely.  When the pattern goes thru to the plotter it uses Cond 8 for cutting but with different force and speed than in my CUT properties in the Plotter setting and different than the Cond 8 set on the plotter itself.  How do you get it to read correctly?
