"nested" patterns
Roman107Roman107 Posts: 3
I requested a pattern from one of our international vendors, and they sent me a DXF file. I imported the file in AccuMark but when I go to open it I see 114 pattern pieces. I was surprised because that particular garment I asked for only has 19 pattern pieces. After I opened all the pattern pieces on Patter Design I realized they sent me nested patterns and individual pattern in each size and non are properly labeled. I tried separating the pattern but PDS does not recognize the pattern as graded, and I get an error and the program closes.
My question, is there a way, when importing DXF files, to select what pieces or sizes you want without actually having all the DXF file imported?
I notice that there is a small window that pops up asking which layers I would like to have imported to AccuMark.
I've attached an image of a sleeve and how it looks like when I import that DXF file.
I hope someone can help me on this matter.
Thank you,
  • Kathy ValadeKathy Valade Posts: 622 Gerber Staff 💛
    edited March 31
    If you are importing a graded pattern, it should be ASTM/AAMA DXF - not Standard DXF. Since you mention a list of layers on import, it appears you are not importing with ASTM at the type of import. Please check and try again to import a graded nest. Also, there is an option for DXF Wizard. If you choose this it will determine if your DXF file is truly an ASTM/AAMA format or not. If it is not, it will be difficult to import as a nest since Standard DXF is not designed to support graded nests like ASTM/AAMA which was developed for apparel-based CAD systems to share data across platforms.
