Max number of model options
SometimesIneedHelpSometimesIneedHelp Posts: 81 ✭✭
I have a list from 2011 showing the max data items and the max number of model options is 999.  Is this still true, or has this increased with the new versions?
You are your own Destiny
  • Kathy ValadeKathy Valade Posts: 688 Gerber Staff 💛
    This is from V14 Online Help - Search on "Guidelines"
    Guidelines for Maximum Number of Data Items
    The following table lists the maximum number of data items allowed in AccuMark when completing and processing editors, reports, utilities, and other functions in an Userroot Based Storage Area:
    Marker: 5000 pieces; 500 bundles; 150 categories (when ordering markers/ 250 categories when attaching markers); 999 yards in length (default =100)
    Model: 250 pieces; 99 options per model; 250 pieces per model option.
    Pieces: 4000 perimeter points; 12000 total points (for order processing and marker making).
    Lay Limits: 150 categories.
    Block/Buffer: 150 rules
    Annotation: 165 categories (150 piece categories, 15 label categories).
    Rule Table: 256 sizes; 9999 rules.
    Matching: 175 rules.
    Alteration: 9999 rules; 999 alterations per rule.
    Size Code: 9999 sizes; 100 alterations per size.
    Order: 99 models; 250 sizes (for all models)
    Piece Plot Parameter Table: 256 sizes; 24 labels; 500 pieces or 1 model or 1 piece list; 20 paste pieces.
    Piece Plot Order: 256 sizes; 24 labels; 500 pieces or 1 model or 1 piece list; 20 paste pieces.
    Process Order: 500 orders
    Marker Plot: 400 markers
    Plot Output: 500 plots
    Cut Generation: 500 markers
    Cut Plot: 500 cuts
    View Marker Plot: 500 plots
    Import: 500 sources
    Export:500 sources
    All Piece, Marker, Plot, and Cut reports do not have a set maximum. Instead, they are restricted to the amount of memory available. These maximums change based on the amount of pieces, markers, plots, or cuts that currently exist in the storage are and if a lookup is used, the amount of memory that is required to perform the lookup.
    A report will display as many items that the system has memory for initially. Then, you may re-enter the lookup and select the remaining items you want to display.
  • SometimesIneedHelpSometimesIneedHelp Posts: 81 ✭✭
    Thank you Kathy!!
    My pleasure! The documentation is new and improved!
    Is there anything in the works to increase the number of model options?
    @SometimesIneedHelp Please submit a Problem & Enhancement Report and explain your reasonings for increasing. Thanks.
  • mirobertsmiroberts Posts: 12
    Just wanted to make sure I understand.  This is per marker not per storage area.  Is that correct?  I know in the past there was a limit on the storage area and the find function working correctly in AM Explorer.
    Maximum amounts described in online help are for data limits in a given marker, model, etc.
  • ElizabethElizabeth Posts: 14
    Can you confirm that v14 has both version 8 and version 9 folders?  I'll be updating to v14 soon, and heard a rumor that it doesn't have v8.  I need v8 for lots of clients
    edited January 20
    V14 supports both V8 and V9 folders. V15 which is the March 2022 release will NOT support V8 format storage areas.
  • VasylVasyl Posts: 1,108 ✭✭✭
    Kathy Valade сказав:
    even for reading?
  • Jaye BrownJaye Brown Posts: 128 Gerber Staff 💛
    Hello:
    V15 V8 storage areas will be read only same as V7 storage areas in current versions.
    Jaye
