DCS3500 x-axis belt runs continuosly after first move after cutting
just finished performing the internal calibrations on this machine and began testing, cut two pieces and then performed a belt move, but the belt would not stop feeding material until an e-stop was pressed. It also brings up the message log (with a message for each piece ~200) that says the piece can not be cut because it is outside the cutting area. The cutting area is larger than the largest piece. Is there a calibration or setting that would cause this?
