Lost space while working with images
Our customer lost huge part of C-drive's space. We fond the Temp folder in profile takes over 45GB.... there are mostly folders with images usen in accumark.
Can we just purge this folder or any solution?
If we purge thid folder will accumar's markers or pieces loose some data?
Usually when You delete something from the drive, Computer just erase it from the Directory but don't erase from the Hard Disk as that process takes much time. Computer just override that portion for new files and saves time. So if he accidentally deleted the files, he can use Recovery software to recover the data and it will work without any problem. There are plenty of freeware and paid software online which will do the task. But You might have to learn how to use them first...
latter the customer was update to v13.2 and for few days called me "C drive full againe". We'd investigate the temp folder in AppData growed up to 45GB. And!!! there are a lot of subfolders with images the customer using in pieces/markers in thisTemp folder...
Major question: can we purge "temp" folder? Will it damage the pieces/markers?
You can move it to any other drive (as a backup) and check if AccuMark work properly or not. Its a simple technique, like when I don't need any data, I put it to a Temp location for a month, then I see if everything is working fine w/o it, then I remove it from there.
You can also take Windows backup before deleting it and if something goes wrong, You can revert the changes...
I know about images library. Cos i moved last one on second hdd (Ddrive). C- on ssd.
the temp folder is in c:\users\...\appdata\roaming\temp\...
