Security key cannot be read
Hello.
I have an Omega 2.6 with Edge FX and Envision plotters.
I re-installed windows. And trying to Graphix Advantage 6.2 (Omega 2.6) too.
But the secret key is no longer readable.
The last time I used it was 2 months ago.
The total lifetime of the secret key is approximately 10 years.
What are my next steps?
Yes, and one more thing: I tried it with Windows 7 - the same result
The security key is present in devices on Windows (with no driver installed). Maybe that's okay - I didn't pay attention before. But the omega installer doesn't see the key.
For example. The AMv8.x not seeing key. Then sentinel from AMv9 can fix the issue.
Cos you may try to update driver. Step-by-step from your version to UP
Thanks for the answer.
I tried options: with Windows 7 (the hardware has been working with it for more than 8 years) and with Windows 10 (with this operating system I have been working at Omega for the last year).
I have downloaded and installed sentinel_system_driver_7.5.8
I got the following results:
1.Windows 7: the USB-key appeared in the windows hardware, with the correct driver installed (at least it says so), but the Omega 2.6 installer still does not see the.
2. Windows 10: the key appeared in the windows hardware with the correct driver installed.
The installer displays a pop-up window and asks me to enter the serial number printed on the USB stick. Moreover, it automatically detects it correctly and substitutes - 1150659.
However, it requires me to enter a value between 520000 and 999999.
Link to screenshot https://ibb.co/YLwyjRp
And here's what confuses. The official manual supplied with the equipment contains the following phrase: “... only use the Sential driver version 7.3.2 that is installed from Omega 2.6 CD. Don’t install the Sential driver from SafeNet website ... ”
I used to do this, I never went online about this, but then it happened.
And I couldn't find driver 7.3.2 for Omega 2.6 anywhere on the internet. Where to go?
And sorry for my English
Else use winxpmode virtual pc...
Or. Update omega
P.S. I don't want to buy a NEW Omega (as a driver) just to make the devices work
