AccuNest Error
Dear I am facing problem in accunest. It give save failed error that is in queue notepad....
Starting Engine FraunCon_x64.exe
Engine started
Engine ended
Checking for piece overlaps
Nest of marker ladies-blouse-1 complete
Storage of marker pending other queued results!
Accunest only nests the markers. Copy/Delete-Server is responsible for writing the results to a storage-area. Check your taskmanager for the processes.
If the copy/Delete-server is not running, you may start it manually. If you receive then a message that you need elevated rights, this may cause the program not to see mapped networkshares which are emapped by the windows-account you are currently logged in.
Please check this before further troubleshooting.
Dear I exit copy/Delete-server and open it again then send marker to accunest but It give the same error.
can you check this on a local storage area? On the machine where Accunest runs, you may send C:\data90\LADIES-BLOUSE to the nester.
Nest of marker ladies-blouse-2 complete
Now I change the drive and marker too. But the error remain same.
This error occurs sometimes with My computers too. Try to create the same window user again (Just login with other admin user and rename Your user folder). If that doesn't help, Create a fresh Queue file. If still doesn't work, Reinstall the AccuNest or Complete Gerber Software with Registry and File Clean option.
Else the last option is New Windows...
Regards,
Owais...
Anyway. Save marker as copy for experiment. And send lastone without option "replace if better"
One more time with checked "restart marker"
Thanks a lot.
What about uncheck "replace only if better"?
Dear I did it but the error remain same.
