Hey, hope you are all well. Is there a notes or video how to use digitizer? I have some internal lines on my hard pattern, but I am able to add only one - pressing H.
@Laiskanese, greeting to all "baltic sisters" and especially Lithuania from Ukraine.
about seems. Not all plotters/software supporting dashed lines. What lastone are you using?
Anyway there are Solid perimetr mast be sew line and cut - dashed - outline in PDS. Some times the operstor have "to fix perimeter as sew"
Yes, Vasyl, you was right. I don't know why I use swap sew/cut command, maybe because I was thought so. I left sew line solid, and now it prints dashed. Only problem that on marker I see both lines solid. But it does not make any difference, because I print them as plt. I use gerber plotter.
Have you tried using label I which is the user define internal?
Just you finish perimeter - press Close/Mirror piece don"t press *.
1. Select INTERNAL LABEL
2. Input label, for example, I
4. Press * to finish piece or back to 1 for next internal.
PS: to input few Drills you may input label D once and indicate few Drills
I suppose you press delimeter * after first internal...
Any way, what Accumark version do you using?
about seems.
