mario сказав: the license is there ... I'll try to reinstall!
Vasyl said: I'd show you how to activate digitizer withouth devicemanager.I got same issue early
Vasyl said: Just digitizer's folder of registry
Vasyl said: What about screenshort of registry?
Vasyl said: @mario, just had contact to customer wih v8.3.1. And check registry conf. There is working well
mario сказав: Vasyl said: @mario, just had contact to customer wih v8.3.1. And check registry conf. There is working well now i am trying to digitize. after doing the reset procedure. everything works but I still have the pieces turned by about 45 degrees
Vasyl said: mario сказав: Vasyl said: @mario, just had contact to customer wih v8.3.1. And check registry conf. There is working well now i am trying to digitize. after doing the reset procedure. everything works but I still have the pieces turned by about 45 degrees The pieces alwase is coming along graine line
Check this topic
https://gerbertechnology.vanillacommunity.com/discussion/1879/digitizer-configuration
If you cannot edit registry editor then configure digitizer on enother PC and copy settings in registry to wrong PC
Anyway you may start wdigit.exe manual now
now i try to instal it with win 7....
Glad to help in non standart situations
